Extreme Networks offers universal hardware products that support more than one Network Operating System (NOS) personality. The universal hardware products share a unified license, which is NOS agnostic.
The Base License, which is included with the purchase of the switch, enables the basic networking capabilities of the device. You can purchase additional licenses separately to enable advanced features on the switch.
Licenses are tied to the switch serial number. After you generate the license through the Extreme Networks Support Portal at https://extremeportal.force.com/ExtrLicenseLanding, you can install the license on the switch manually. You can also use ExtremeCloud IQ to obtain licenses for universal hardware switches.
The following sections detail the different categories of licenses.
A Base license gives customers the right to use Base software features on the switch.
Licenses enable advanced features not available in the Base License. The following table provides information on the features enabled by each license, if the hardware supports the feature. For information on supported features, see Fabric Engine and VOSS Feature Matrix.
Platform | MACsec License | Premier License |
5320 Series 5420 Series 5520 Series 5720 Series |
IEEE 802.1AE MACsec |
7520 Series 7720 Series |
IEEE 802.1AE MACsec (7520-48YE-8CE) |
The following table lists the license types and the associated part numbers.
License Type |
Platform |
Part Number / Order Code |
MACsec License |
5000-MACSEC-LIC-P |
MACsec License |
7520-48YE-8CE | 7000-MACSEC-LIC-P |
Premier License |
5000-PRMR-LIC-P |
Premier License |
7000-PRMR-LIC-P |
